Yesterday coming home from work I floored it going up hill on an on ramp to merge onto the highway. It was at 10lbs boost in third gear and everything was fine until 4000rpm. I believe the clutch slipped a little. I think the clutch slipping put too much side force on the front input shaft bearing. The over-stressed input bearing may have let the input shaft move out of alignment resulting in a chipped a tooth on 3rd gear. Third gear now clicks as I drive! If I give it a lot of power in any gear the input shaft bearing starts whining.
The good news is could still drive it if I went easy.
I bought a 2014 2TR-FE bellhousing off ebay this morning for $170 shipped.
I then drove the truck to pick up a stronger transmission today. I used car-part.com to find a pre-1995 3VZ-FE 3.0 liter V6 R150F transmission with the short 6.5" input shaft $375 72,000 miles on it $20 core charge. When I got to the junk yard they didn't want to take the time to separate the transfer case so I got that free!
With the 2TR bellhousing I should now be able to put the much stronger R150F in place of my stock W59 transmission. If I sell the extra transfer case, two extra bellhousings, and scrap the W59 the cost might not be too bad!
Now I'm shopping for a clutch. I did a little bit of shopping around and Competition Clutch stage 2, 3, & 4 seem to be used by many on here. I was thinking I could probably get away with the stage 3. This is my daily driver so I don't want a 6 puck disk. I also don't want a 2100 lb pressure plate if I can avoid it. The stage 3 has a 1600 lb pressure plate and a streetable disc. This is the only opinion I have heard about the stage 3:
Anybody else running a stage 3? Will it hold 327 wheel torque?
