Pinch Weld Mod
8.8K views 16 replies 10 participants last post by  James
#1 ·
I used the search first and nothing came up that was helpful. I hear everybody talking about a "pinch weld mod" that helps with rubbing problems. I was just wondering what this is and if anybody had a picture of it. Thanks!!!!
Ryan
#5 ·
Nah, I never like to rush a project on the truck, so I wouldn't want to do it in parking lot before wheeling. Plus, then we'd be missing wheeling time.
That link has a good write up on it.
Honestly, I haven't done it. I don't rub hard enough to worry me. I rub more in the rear than I do the front. Ok, this is starting to sound bad
#6 ·
neat! that's simple enough. I saw over at ttora that a fella was running 307/70/16's on a xcab with only a 3" CF lift..........shouldn't i be able to clear 285/75/16's on stock or MT II's without problem with coil and shackles? i've been told absolutly no way i'll clear 33's without at least 5 inches and i could clear them ok (but lots of rubbing off road) stock. i think the truth is somewhere in the middle.
#11 ·
you could run 33" 's stock if you got the fiberglass wide body fenders, but at that point, you might just want to get the suspension lift. though im going to be getting both someday. lift first.
