so this sound has been happening for awhile now and it just got worst. the sound is coming from the front right wheel area. its like a squeal sound when i coast or accelerate, kinda like a whirling sound but with high pitches. I already changed the break pads and rotors so thats out of the question. I’m thinking my wheel hub, wheel bearings or axle needs replacing. the sound gets loud when i coast between 10-30 mph. help?
Toyota Tacoma 2004 extended cab Prerunner
(1) Welcome to CT! :waytogo:
(2) Did you check the caliper to make sure it wasn't sticking or grabbing?
(3) My first guess would be wheel bearings ...
1) thank you
2) had new calipers installed last year. should be fine?
3) so im trying to find wheel bearings online but can only find the bearings and not the hub. is it harder to install wheel bearings into the hub? is this install hard to do without a mechanic?
