I’ve recently have had a problem with when I go to crank my truck after the engine is warm it idles then shut off a few days ago I came to start it it turned over but didn’t fit up took the throttle body off and found this
Automotive tire Bicycle part Motor vehicle Rim Electrical wiring
Hood Automotive fuel system Vehicle brake Motor vehicle Automotive tire
Should I replace or just clean the iac sensor after I clean the throttle body and air intake manifold and any recommendations on cleaning everything?
Probably would not hurt. Did it show any symptomatic problems (off idle, rough running etc) prior?
Discussion Starter · #3 ·
Yeah sometimes when I’d stop and get gas it’ll idle then cut off and I’ll crank it up and put it in drive amd it’ll idle fine
Check your fuel pressure and regulator too. If fuel in regulator line replacement of reg needed.
But could be so obstructed it can cope. Clean and run it again see if improves
