I take it you have an A/N bung on your oil pan?? Just install a plug for it and be done....right? You can find them on Summit.com, either Earls or Russel makes them.
I take it you have an A/N bung on your oil pan?? Just install a plug for it and be done....right? You can find them on Summit.com, either Earls or Russel makes them.im not sure if this post is in the right place, but does anyone know where i can buy/ make a cover that screws onto the threads for the oil drainage return from the turbo located in the oil pan. When i take my truck for smog and have to return to stock, i want to stay away from removing the oil pan.
