1 - 20 of 42 Posts
Hey guys, on to my next issue to sort out lol
98 4Runner
5VZ Turbo with FIC6
I have noticed while cruising usually freeway speeds around 60MPH, 2200RPM and between -10 and 0.
The 4Runner will buck/jerk pretty bad and I noticed that when it happens, the AFR's will shoot rich/lean/rich/lean. I took a short video of the wideband when it happened, sometimes it happens for longer periods of time.
I also took a few logs and captured one with the "engine load" signal that just drops off for a quick second (suspected to be my issue)
Looking for ideas of what it may be, my only idea is maybe the cam/crank wires on the FIC6. It was wired up according to this: https://www.toyota-4runner.org/3rd-gen-t4rs/201223-how-aem-f-ic-6-install-tuning-help-thread.html
Video: In worse cases it will go full rich to full lean. It is hard to catch it on tape since it is random...
Random surge by Sean Miller, on Flickr
graph:
Engine load drop by Sean Miller, on Flickr
If it's a software/tuning issue: Attach your FIC6 map so I can scrub it to see if there are any "conflicting" values with other tables.
The only time I've encountered this, and the culprit was wiring, is when my AEM FIC wasn't getting power steadily because the power tie into the ignition was bad.
Didn't someone say you might have a bad TPS or fuel table issues in another thread?
https://www.customtacos.com/forum/2119327-post27.html
https://www.customtacos.com/forum/13-performance/183002-5vz-fe-trd-sc-2-1-pulley-318cc-injectors-aemfic.html#post2119329
First, when you say attach my map you mean like just a picture or something? I can do that after work but I can tell you now that my maps are zero'd out until boost and the issue normally happens while in vacuum.
I feel like wiring would cause this but all my connections seem to be good, I soldered all the "ties".
Someone did say TPS and I can see that causing it, my only issue with it is that it tested fine for voltage and resistance. Shouldn't I see a dead spot? Why would it only happen between 40-60MPH? I would rather it be a TPS issue over wiring though. I suppose I will start shopping for a TPS and just pull the trigger on that and see what happens. I wish it would just throw a code... :|
The AEM file. The .fi6 file. Put it in a .zip file, as I don't think CT.com accepts or allows .fi6 files.
Maybe that's the sweet spot. >:D
I'm not seeing any conflicting cell values that are jumping out in front of me, but I did notice something.
Perhaps running your O2 in voltage mode and creating a voltage/O2 table might work. From the installation instructions:
“Voltage” mode - The F/IC outputs a voltage, which is determined by the
corresponding cells in the “O2 Map”. In the “Voltage” mode, for an “O2 Map” cell
value of 2.5, the F/IC will output 2.5 volts. In “Voltage” mode, a cell value of 0
makes no change, NOT an output voltage of 0 volts.
“Fixed” mode - The F/IC outputs a square wave that alternates between the Bank
Hi voltage and the Bank Lo voltage. The Bank Hi voltage, Bank Lo voltage, and
square wave period are set in the O2 section of the setup window. The pulse
width is determined by the cell value in the “O2 Map”. For a Bank Hi of 2, and
Bank Lo of 1, a period of 200 ms, and a cell value of 50, the F/IC will output 2
volts for 50 ms, 1 volt for 150ms, 2 volts for 50 ms, etc.
“Percent” mode - The F/IC will measure the O2 voltage, then modify it by the
percentage value in the “O2 Map”. For a measured value of 1 volt, a period of
200ms, and a cell value of 20, the F/IC will measure 1 volt for 5ms, then output
1.2 volts for 195ms, then measure again for 5ms, etc.
“Offset” mode - The F/IC will measure the O2 voltage, and then modify it by the
offset value in the O2 map. For a measured value of .7 volts, a period of 200ms,
and a cell value of -.25, the F/IC will measure 0.7volts for 5ms, then output 0.45
My 02' 2rz liked percent mode. My 01' 5vz likes voltage mode. You could possibly be using a mode that (somehow) freaks out the ECM. I'm just guessing, but if you can skew your O2 a different way, it may work -- wild guess. Other than that... TPS or wiring gremlins?
I took a peek at your tune as well and found the problem.
Not everyone has encountered this issue, but I have as well. The bucking/surging where the AFR's jump all over is when you have two fuel maps active at the same time. This includes the O2 sensor map. It only does this when the second map become active, so when second fueling map goes from "0" to a value. For you, this is happening at 14.7 PSIA when your O2 and fuel tables become active at the same time. It also only bucks on the transition from 1 map being active, to 2. If you push into boost past that "transition" then it runs fine. If you were to remove the values in the O2 map at 14.7 and instead have it start skewing the O2 signal at 16.2, you'd notice the bucking start partial throttle acceleration when you hit 16.2 PSIA instead of 14.7. I never did get rid of it 100% but I've moved that "crossover" from around 15 PSIA to more like 21 PSIA and I'm normally in open loop at that point. Your saving grace here is that once the stock ECU sees it under heavy throttle or WOT, it ignores the O2 sensor skewing (and your O2 tune) and then the AEM is only running on one map again so the bucking goes away. It has something to do with how our stock Toyota ECU interprets the modified signal from the FIC 6.
If you want to minimize the bucking to as little as possible, zero out your fuel table in closed loop. It's going to take some time to figure out when the engine switches from closed loop to open loop (closed loop it takes in the O2 sensor readings, open loop ignores them) and obviously you don't want any spots with no tune. I'd start by zero'ing out all fuel table cells at 14.7 and maybe even 16.2 PSIA. This will at least push the "bucking" into the higher RPM's and better chance of the engine being in open loop. You have a turbo and not a S/C though, so you'll need to draw from your experience to know when it's building boost at what RPM's and what throttle level. The logs can be helpful if you overlay the TPS/throttle % and run a few partial throttle runs. Just know that once it enters open loop, your O2 map is completely ignored.
If you want, I can post up my maps on how I eliminated the bucking.
One other note, for sake of gas mileage you probably don't want everything skewing at 14.7 which is atmospheric pressure at sea level. Unless you live at elevation, you'll be burning through fuel when you don't need it. The AEM FIC software automatically smooths between the two values. What this means is, at 12.8 PSIA you have a value of 0, and 14.7 a value of -0.174, so skewing the O2 sensor to run rich. However, at 12.9 PSIA through 14.6 PSIA it's also skewing rich, on a sliding scale until it reaches -0.174 at 14.7. Make sense? Same goes with your fuel table, it's adding extra fuel from 0 at 12.8 PSIA to roughly +2.3 at 13.8, then +4.7 at 14.7 PSIA.
My O2 begins skewing in voltage mode at 14.7 MAP and 1800 rpms (from 14.7 to 14 AFR). A voltage value somewhere around 2.6 volts according to my table. I'm not bucking.
I think the O2 sensor takes it's reading of the voltage from the middle of the sensor voltage range on my truck. I'm not the only user that has experienced that at 0.05 volts, I get the richest AFR's possible (12). Yet, at 0 volts, it equates to the truck running at 14.7 AFR. From 0.05 to 3.36 volts controls the O2 sensor from 12.01 - 14.6 AFR. Now I understand he has a narrow band sensor since he has his Bank1 high voltage set to 1.1 volts, but does the sensor follow the same weird wide band behavior described previously (this is a rhetorical question)?
I'm not sold on the two maps active diagnoses. Yeah, this can happen, but he has to be doing more of a severe tuning difference deal to make it buck in my experience. But... in offset mode with a -0.174 volt offset.. I mean, I have no idea how much of an AFR change that is on a Toyota narrowband O2 sensor, but maybe doing it that way is incompatible with the Toyota ECM clock speed?
Heck, he could have water in his charge pipe and when boost hits, it's just enough to suck the water to splash the MAF sensor (yes, this has happened to me) and make the truck freak out.
Like I said, not all experience this issue with the AEM unit. I was one of the unlucky ones and it took me weeks to figure it out. I'd adjust the tune again, and again, and again and nothing helped. I even tried negative fuel amount, so pulling fuel. Ended up zeroing out the entire fuel table and the problem went away completely, then I figured out what was going wrong.
Since I know you read the manual, this is what clued me in as to why it was bucking: "Keep it simple. Many times it is not necessary to use every function of the F/IC to obtain the desired engine performance. If the desired engine performance can be achieved by adjusting only two maps, use only the two maps. There is no benefit to adding fuel in one map and removing it in another." Or in this case, there is no benefit to adding fuel via the O2 skew, then adding even more via the fuel table. It just makes the ECU freak out with the mixed signals. The stuttering/bucking isn't like it slogging, it's literally cutting out fuel completely and then dumping it on, then cutting it out again, all several times a second. It feels like hitting the speed governor, if you've ever done that.
Once he zero's out a few rows of fuel table data, the problem will go away, I promise.
Gamefreakgc, what .hex are you running, what year is your vehicle, what O2 mode are you running?
Not sure which .hex I'm running, whatever one it came with. I remember reading about it when I installed it but haven't touched them.
I have a 98 4Runner like the OP, so that also might be the issue? Maybe Tacos play nicer. I have a narrowband O2 sensor which limits my options a little so I'm just using the offset mode, also just like the OP who also is trying to skew the narrowband sensor.
The .hex slaves are in Windows documents folder (C:\Users\garet\Documents\AEM\FIC in my case). This is kind of a last ditch for fixing the problem. Has to do with how the injectors are controlled, could possibly support the injector map clashing with the O2 skew map if it worked... just a thought.
Z104 Fueling strat should be used for vehicles that are Pre OBDII with Distributed ignition
Z107 Generally used on early OBDII vehicles
Z110 Used on Late OBDII vehicles with Modern injectors that have unique spray patterns rather than conventional open/close type injector.
Oh good, so did you try different O2 skewing modes as well? Was the narrow band sensor unresponsive to changing the O2 skewing mode to voltage, offset, or percent all w/high level drive on/off? I've had sensors respond to percent, but not voltage. I've never skewed a sensor on offset.
Maybe consider a flash or different skew mode, if those options have not yet been exhausted.
I tried high level drive for a bit but ended up going just with the normal since it was responding very well to it. I could get more pinpoint target AFR's with the narrowband, they are more picky than the newer Air Fuel Ratio sensor Toyota switched to a few years later. For example my sensor didn't even come close to moving the AFR's until about -0.4 offset, and -0.48 is 11.5 AFR. Since the AEM unit only moves 0.005, each move changed the AFR pretty dramatically. With high level drive on it made it move even more so it limited the values I could use.
I didn't try % change since I'd have to re-do my entire O2 map, including the data points for what %'s get what AFR's but if it comes to that it's worth a shot. Same with flashing the unit. My tune is (was) awesome where I have it now though, but now I need to re-tune it soon once the weather improves for the JDM engine I just dropped in last month.
Discussion Starter #16
Back again, I have been driving and adjusting things on my rig to try to find the bucking issue. I have read your suggestions and took them all into consideration. I think the issue I have been having is when the AEM kicks on. I do believe at this point in time that it may be too much of a shock and is toying with the factory ECM. I noticed that it had gone away after resetting fuel trims. So I have sort of changed up my whole O2 map so that the AEM is under control in vacuum and slowly adjusts into boost so that it does not have that immediate "shock" to enrichen. So, now that the whole O2 map has been changed I will be adjusting the fueling to keep the STFT in order.
Let me know if you find a permanent solution. I've also noticed resetting the fuel trims works for a little while but eventually comes back. I need to completely re-do my fuel trims (need a dry weekend to do it, too much rain) since my new engine doesn't like the old tune at all. Runs pretty sloppy on it.
I'm also going to try out garett's suggestions of trying another O2 skew method. Might try percentage this time around.
No need to do an entire map just too see if it works. Just warm the truck up to operating temperature and rev the truck to 2k rpms and try skewing the O2. If there's no change (leaner/richer) while you change it on-the-fly, then don't bother trying an entire map.
Pretty much this video at 154 seconds, but obviously in percent mode:
I don't know if ya'll are using a resistor right now, but I want to say I had one installed when using percent mode.. either a 1k or 10k ohm 1/4 watt.
https://www.youtube.com/watch?v=GZNDCT9UjQQ&feature=youtu.be&t=154
I also have the resistor, it doesn't play nice without it. That's exactly how I plan do retune the O2 skew. It's sort of odd, but when I swapped engines my O2 sensor skewing is now too rich? Same injectors, same O2 sensor but now it seems my engine likes less fuel, kind of scratching my head on this one. I did lose almost all compression in cylinder 6 so maybe it was pumping fuel down the exhaust non-stop and the O2 sensor was adjusting to that? Anyway, I need to re-do both the skew map I have then save a new one in percentage mode, maybe even try the AFR mode if I can get it to play nice with the narrowband (not very optimistic though).
Had some time to tune and been driving it with the new tune for about 3 weeks. The bucking is completely gone! The secret? I should have thought of this before, but remember how the "transition" from 0 value to a fuel value was the culprit? Yeah, just make sure there's no 0's. Duh.
The 0's in the mid-boost range do not affect anything, since if you know the AEM software it "blends" the values in between RPM so the ECU only sees a true 0 for a fraction of a second.
Anyway, new tune is attached for reference, hope it helps.
P.S. ignore the top 3 rows on the fuel table, haven't tuned for WOT yet, roads have been too wet on weekends.
1 - 20 of 42 Posts
