is your toxics made for 3/4? whats your part number? i think i got the wrong set a toxics today but they called the company and said that the ones i have ( not -3/4 but 0) should work fine
stock number 413515 for the front...and 419500 for the back. 3/4 shocks. anyways...how do you get those bottom bracket type of bars through the urethane bushing on the bottom of the front shocks.
i am having the hardest time trying to put in those freakin metal bracket bars that are suppose to slip into the the bushing of the bottom of the front shock. its used to bolt in the shock at the bottom to keep it in place! GEEEZ!!!! this is really bugging me!
whats the easiest way to go about doing this without breaking an arm!!?? HELP! i've been stressing over it for the past hour!
If you don't have a rubber mallot, line up a piece of wood with it and give it a whack, some lubricant wouldn't hurt, NOT WD40 though, it can cause the rubber to swell.
