Make offers dont be scared. All this must go all of it. pm me or post up I can get pics of anything if your seriously interested
01 tacoma 5 speed trans. Does not come with bell housing but you can reuse your original one.
6 puck ceramic clutch used but in perfect working condition
lc engineering 11 pound flywheel used but in perfect working condition. never needs resurfaced just replace the bolt in disc and its new again
01+ 2.4/2.7 valve cover
stock 03 2.7 coil packs perfect working condition
glassworks desert kit used for mock up but never mounted, three pieces two fenders and hood same as whats on my race truck. hood has to arches cut on the front for tubes to go through to an engine cage. can be patched with minor fiberglass.
also the front fiberglass kit from the race truck is also for sale and is the glassworks desert kit. has some minor trimming and some defects but perfect working condition. minor fiberglassing to repair
possibly tundra rear end drum to drum with tru trac tig welded strong to make it a spool with 529 gears ready to mount on top of leafs as in my race truck for 62's or whatever. also has stock tundra spring perches still mounted. also has shock tabs on it and bump pads welded to it. pics of tig welded locker if needed.
dj safety tacoma or pretacoma window next. all that is needed is the self tapping buttons for the truck side and the nets are ready to snap on
stock 3.4 intake manifold cheap cheap
15" electric fan
8-10" electric fan bought for 80 for trans cooler. this one is perfect for those tacos with a hayden trans cooler and wanting that extra cooling on your trans. this fan blows like crazy
2 larger size ammo cans. about 8-10" wide and about 12-16" tall and about 12-16" long
Stock 2.7 fuel rail and injectors from 03 taco
stock front coils from 01 regular cab mini 5 lug
20lb C02 tank used for my airbags
0-500psi c02 regulator
rear 2500 firestone air bags pair from turbo truck
front hs slam specialties air bags from turbo truck look like there weathering alittle but thats what they do they are super super thick
DJM or whatever upper control arms cut on a mill to fit for bags just the outter plate took off a little bit.
6-8 smc 15mm valves i think i have 8 but maybe only 6
front steal braided lines and tank to front steel braided line
rear 7 gallon tank
all the fittings
switch box i made myself
rc10gt needs some tlc but runs great and is complete
drag radials on 14" black stockies plenty plenty of tread left on them
01 up little cup holder that has a C shape you click tighter to clamp it. i think its an add on to the end of the center consoles or soemthing
fuse box and wiring from a 98 3.4 taco. its the one under the engine bay. the main fuse box
QTY 4 of 315/75/16 with usable tread on some MAxxis mud terrains some weather cracks but perfect to use for mock up not really wanting to trash them and its hard to find somewhere. im sure someone can use them...
2 stock star style trd rims with 285-16 BFG mudd terrains with usable tread left
low profile edelbrock dual carb manifold for 440 mopar engine
two 750 carter AFB carbs with fresh rebuild for sale as well. willing to sale the whole dual carb setup with manifold if wanted
coilover spacers for up to 3" lift for sale as well
mechanical oil pressure guage mising light socket and bulb silver face 2 1/16 full sweep
that is all for now. i will have more updates as i go.
15" electric fan
rear 7 gallon tank
all the fittings
