id actually like to know the same thing. i wanna do my extended cab since my sub rattles the hell outta my truck
i would like to know the same. ive seen threads about flashing and insulation working but are they really as good as the name brand sound deadner?I can't wait to do mine this summer! what's the difference between sound deadeners and other options like insulating?
then I would go with dynamat. It's expensive but awesome.I don't really care about road noise I want my subwoofer to stop rattling my cab:lol:
did you check out the SS damplifier its cheaper than the pro but still alot better than the RawMat.Thanks all! After much reading and research I decided that RAAMmatt was the best product for my needs. Im planning on doing the doors and rear wall right off the bat, and then maybe the floor this summer when the weather gets better.
It seems the general thought is that doing the doors makes for a huge improvement in sound system and overall quietness. Im hopeful I experience the same!
When you work on the doors, be sure to use the Rammat on the outer door metal. Do not just plaster it over the plastic liner on the interior side. Take the time to get as much dampener on the exterior steel. This is the only place that will make any difference. Carefully peel down the plastic and remove the metal panels that are screwed in place. Even remove the speakers. This way you can get your arms inside to place the dampener and reach everything. Remember, the only thing that needs to be covered is thin steel. The impact bars, etc. are solid and won't matter. You will get a nice, solid door feel as well. When guys paste the material on the interior, covering the plastic and everything, they just make a mess when you need any service and it doesn't do any sound dampening either.Thanks all! After much reading and research I decided that RAAMmatt was the best product for my needs. Im planning on doing the doors and rear wall right off the bat, and then maybe the floor this summer when the weather gets better.
