1 - 1 of 1 Posts
I make 6 different tiedown kits for Tacoma and Tundra with a number of options. All are based on the bed floor bolts and are very strong.
I’m currently selling them on eBay. I have D-rings and V-rings, with and without New Toyota factory bolts with washers removable.
Some bed bolts come out relatively easy with a T55 Torx driver. Others can be rusted into the frame. Depends on age and location. But in any case, the washer is captive with hardened ribs. You can reuse your old bolts and grind off the ribs, or use one of our kits with brand new bolts.
I can’t post a url here, but easily search for part numbers.
Tacoma 5min Painless NoDrill Bed Tie Down Kit with New OEM Bolts TA64002
Tacoma 5min Painless NoDrill Bed Tie Down Kit w/T55 Torx Bit & OEM Bolts TA64003
Tacoma 5min Painless NoDrill Bed V-Ring Tie Down Kit with New OEM Bolts TA64004
Tacoma 5min Painless NoDrill Bed V-Ring Tie Down Kit w/T55 Bit/OEM Bolts TA64005
Tacoma Painless NoDrill D-Ring Pair Bed Tie Down Kit (No Bolts) TA64006
Tacoma Painless NoDrill Bed V-Ring Pair Tie Down Kit (No Bolts) TA64007
This is the painless no drill way to strong tie downs.
Kevin - Hollywood Controls
1 - 1 of 1 Posts
