I have a 1996 Tacoma Standard Cab 2WD. Does this vehicle have front end sensors, or is the only sensor located in the module located on the floor under the radio? I have a SRS light continuously. I removed the airbag from the steering wheel and read out the clock spring all the way back to the module; continuity good. Toyota dealer said the module was dead, but Toyota no longer supports the part, so I got a replacement from Airbag Center in Florida. After replacement the SRS light didn't come on at all, making me suspect that the replacement is bad. So either the airbag itself is bad or there are sensors that I can't find to check for bad connection or corrosion. Also, can the SRS be read out through OBD. Failed inspection and is parked. Any help appreciated. Anyone have a schematic?
