Hello all, I have just fabbed and installed theses spindle spacers for the 1st gen Tacoma. Made the world of difference. It will give you the same drop as a ball joint flip however will retain the same steering geometry as stock in the lower control arm assembly. This results in no bump steer. The problem with doing a ball joint flip is that it changes the lower control arm geometry and will give you toe out under compression as the steering tie rod is at an increased angle relative to the lower control arm. Toe out is twitchy and will make the truck pull to the direction the bump occurs. I would like to offer these to the customtaco community. I have a couple of these prototype sets available for 50 bucks a pair. If any one is interested, give me a holler and I would like to produce more for the future.
4130 Chromoly Steel
Powder Coated Black
[email protected]
4130 Chromoly Steel
Powder Coated Black
[email protected]
