So i have been hearing that you can use a hilux solid back glass on a tacoma, just wanted to know if anyone can confirm how true this is. If this is true, that would be great being that hill glass are more common to find here then tacoma
But what would be the difference from 2000 taco to a 2004? did the dimensions change? Or what is the dimensions of a hilux back glass and a tacoma?
I've never seen any detailed dimensions for any rear window glass, so as far as I know there isn't any ultimate reference one can check.
The cab was slightly redesigned for the 2001 - 2004 era, so I'm not sure whether rear windows are the same for that era versus 1995.5 through 2000.
I can tell you this ... The Toyota and NAGS part numbers for rear window glass change from 2000 to 2001. The problem is that I don't know whether this resulted from a change in dimensions or just a change in OEM glass tint / coloring.
