Both are good choices buy the 57 will give you more up top
Thanks guys,
Garrett 57-trim ordered 5 minutes ago.
Tuning suggestions?
I was seriously considering an AEM FIC unit with a PNP harness but looking at the Split Second MAF Calibrator this looks like it will work just as well.
Thoughts?
I know ultimate tuning is best with a standalone....but well, ya know...
Thats what I thought when I was running the Greedy Emanage Ultimate it is a very good controller, but once you turn it up, things arent so easy, like I said in one of the earlier posts they work great until your in the 15psi range, as I found out.IF you are going piggyback get the FIC its got alot it can do in one unit for being a piggyback compared to others that need to add other piggybacks........I only paid 320 shipped for mine........I has a timing map, MAF map, Fuel map, MAP map, 02 map, analog A map, anolog B map..........and other stuff like RPM, AFR and load guages......I just put mine in and am getting to know the program.......but it seems pretty easy to use coming form a guy who is new to tuning.......I wired it myself with zero problems:waytogo:
Maybe you aren't very elite. :nana:But maybe others have better luck with other piggys than I did.
