1 - 6 of 6 Posts
I have a 97 Auto that shifts on the column. The little D on the dash is now burnt out. The P-R-N-2-1 all light up, but the D is just black. I'm assuming the bulb is burnt out?? How do I fix it :confused:
Discussion Starter · #3 ·
I attempted at taking the instrument cluster off, but I can't get it off. I have a 97 which has the mechanical speedo/odo. How do I disconnect it??
You should not have to unplug it to change the bulb. You should be able to pull it out far enough to reach the bulbs.Or you can always buy a 5 speed and forget the indicator. Good luck.
Super Duper Tundraholic
nah just get a new bulb. If you already have the dash apart, you might as well put all new bulbs in.:waytogo: Well that's what I would do.
1 - 6 of 6 Posts
