bump stops are key, you dont want your spring to go neg. arch
how long are your shackles? what does your pinion angle look like??
What suspension setup are you running up front?
I ended up doing the trail gear 5"HD leafs and made my own shackles. When I set it on the ground the rear of the leafs swing up and hit my frame. I haven't added the shocks or bump stops yet. Would that make a diff if those were installed. I'm wondering if I need to do a diff setup.
I understand that but would the rear of my leafs touch the frame without them? Do your leafs sit on your bump stops when not moving?bump stops are key, you dont want your spring to go neg. arch
Thanks. You can check out the whole build thread here. http://board.marlincrawler.com/index.php?topic=64393.0:jawdrop::drool: Dude, that is just sexy right there! Nice work!:bow:
