rear brake conversion
1.4K views 9 replies 9 participants last post by  OGSpacePimp
#1 ·
Is there a company out there that has a kit to convert the rear drums to disks??? Is there any way to convert to disk in the rear??
#5 ·
is that really necessary? like will it help that much?
nothing is ever really necessary.. braking will improve im sure.. pads where always better than shoes... plus it just gives a much nicer look if you got nice rims... who wants to see those nasty ass rusted drums
even though easily painted... the discs are just better
#6 ·
Its from a kit to convert the older style axle to rear disc. I am about 99% sure I can make it work on a taco. I just need to verify it on a taco rear. As for performace, hands down 100% better. The biggest thing is to get the proportioning valve set right, otherwise the rear locks up befor eteh front and you dont want that. I've done it at 70mph on a 4lane raod when some dumb B$%#h pulled out in front of me. Talk about going sideways. Anywho, they look 10 times better behind the wheels too.
#8 ·
what about the lexus utes? or 4 runner? they are coming out w/disc in the rear, stock....rx330 has a five lug pattern....might be able to bolt up w/ min mods? might be worth checking the wrecking yards for compatablity
#10 ·
When you do a rear brake conversion you need to get change the psi to the rear brakes from 6psi. (stock) down to 2psi, Downey Off-Road sells it for like $30. You could also buy an adjustable brake proportioning valve for like $80.
TACO'S HAVE BRAKE PROPORTIONING VALVES IN THE REAR ALREADY, JUST NEED TO ADJUST THE ROD
oops, sorry about the caps, kids bangin on my keyboard again i guess
