As long as you don't plan on removing your rear O2 sensor, it will work beautifully. I ran one and had no problemos whatsoever.
how was it wiring it inAs long as you don't plan on removing your rear O2 sensor, it will work beautifully. I ran one and had no problemos whatsoever.
has anyone who removed their cat and ran no sensor or replaced their sensor with a plug n play experience this recalibrating from time to time?http://www.urdusa.com/index.php?cPath=66_170&osCsid=p77ahtl10f2q7e37c9asqq5bk1
Rear O2 Sensor Simulators are used in off road/racing vehicles to prevent the check engine light from illuminating and to prevent an ECU code from tripping. URD Rear O2 Sensor Simulators are carefully calibrated to condition the signal from the rear O2 sensor to keep it in the range the ECU is expecting to see. DO NOT USE ON A PUBLIC ROAD OR HIGHWAY ANYWHERE IN THE UNITED STATES.
Note: Be cautious of O2 sims that replace the rear O2 sensor with a falsely gererated signal.
Toyota started using a wideband type O2 sensor (air/fuel ratio) in the front position for better engine control. These wideband type sensors need to be recalibrated from time to time by the ECU. The ECU uses the rear sensors for this recalibration process. The ECU cannot properly recalibrate the wideband sensor using a falsely generated signal. This process is explained here, US Patent 5706654.
Use only a URD O2 Sensor Simulator on these vehicles to avoid poor performance, drivability issues and poor MPG.
mine came on about two months after I installed the 02 sim and I cleaned my MAF and that fixed itmy CEL just came back on today on the way to work after about 300 miles of driving..im pretty sure that it is not the o2 sim i might just have a leak..
i might just try that..mine came on about two months after I installed the 02 sim and I cleaned my MAF and that fixed it
I was freaking out thinking that the sim quit working:lol:
