I could be wrong about this... Need a stereo guru to chime in.
Alright, so the short of it is, I'm hooking up my mids and highs and can't decide how I want to do it. I have an Alpine HU with preouts for front, rear, and sub. The HU has an adjustable crossover in it. I'm using the sub out for a mono Alpine amp. I will be using the Front out for a PPI 2 channel with built in crossover and rated at 2 x 60w @ 4 ohms. In the doors I have Boston 2 ways rated at 40/160w @ 4 ohms and JL tweeters with inline crossovers rated at 70/175 @ 8 ohms. Can't I just run one wire to each of the Bostons and loop them up to the JL's? Do you mean channel instead of wire? Your PPI is a 2-ch amp (2 pairs of wires, one pair for L and one pair for R). I don't think that'd be a good idea to "loop" the wires (ie, connect your speakers in parallel) or should I run one of these two off of the HU which might have 12 watts? Yes, run the tweeters off the HU and 2-ways off the amp. Any other ways I could wire them up correctly?
