for the street you dont want drilled rotors, unless that is you wanted that for looks. for the street i might choose slotted, diamond dimpled (or just dimpled), or a combo of these two. you dont even need that, just take a look at what Mercedes puts on their big cars, standard rotors......Or Tundra calipers and rotors up front. It's an inexpensive big brake upgrade, even though the difference doesn't feel like much. I should have got the Brembo drills cross slotted rotors, but they were twice as much!
All Pro also has a rear disc brake kit.
i would not use them to 4x4 with, they collect and store dirt. they are used to allow out-gassing from very hot hot pads to help fight fade, etc.So, I'm assuming if you wouldn't use drilled rotors on the street, you wouldn't use it off road either? Do they not get hot enough in non-racing conditions to really take advantage of it? I've learned that high quality drilled slotted rotors from companies like Brembo (and not some small machine shop) don't warp and crack, but still wear through pads more. Since Autozone has their awesome replacement policy, I thought maybe I could have gotten the drilled slotted rotors. Why do you advice against?
Also, I didn't know the first couple posters had 2WD, so disregard the Tundra comment. Tundra calipers and rotors are for 6 lug trucks.
LOL! But but but!! :doah: :lol:Dammit guys, go to www.sosperf.com, downey only has 4wd kits or non-tacoma kits... yes, they have discounted prices!
Shizukani, bakayoru! :lol:LOL! But but but!! :doah: :lol:
ok, but which ones will fit a 98 2wd? all that i see listed are 05+tacos, maybe im missing somethingDammit guys, go to www.sosperf.com, downey only has 4wd kits or non-tacoma kits... yes, they have discounted prices!
