1 - 8 of 8 Posts
this is pretty stupid but the radio will not work in my truck but the cd player will.... is this a problem in the antenna or should i go buy a new radio???
thanks
Maybe you could elaborate on how it does not work. Do you not hear anything? Screen goes blank? Can you choose a frequency? Does it pick up a frequency when you scan? Etc...
... And what kind of head unit is it? ... I don't believe there was such a thing as a factory CD player for 1993 PreTacos ... :thinking:
Discussion Starter #4
to elaborate... i simply dont hear anything... i can choose a frequency and everything... but cant hear anything... its a Pioneer Super Tuner 3...
Does it find frequencies when you scan? Was it working before? When did this problem start?
which means from the early 90's till now...
what model ? DEH-????
disconnect your antenna, and put a long wire into the center contact of the antenna plug and see what happens.
if it still wont play the radio, you most likely need a new tuner module.
depending on the model and how old it is, it may be worth it to save it.
if so, send it to me... i have the modules in stock. it is not an expensive fix.
dave
1 - 8 of 8 Posts
