Yes you can. the stock 16's will work with a 1.5 spacer(hubcentric) or a aftermarket wheel with more offset and a smaller spacer. some people use a 5/8 spacer with 16x10's but that need the tierod to be shaved
cant you fit the 16" TRD off-road wheel cause it has a 5.25" BS and then throw on a 1.25" wheel spacer?Yes you can. the stock 16's will work with a 1.5 spacer(hubcentric) or a aftermarket wheel with more offset and a smaller spacer. some people use a 5/8 spacer with 16x10's but that need the tierod to be shaved
