Just so we're clear - exactly *which* older Toyota axle do you have? 1989 - 1995 PreTaco? Or ... ???
The Perches on the older axle do indeed mount directly to the tacos leafs. However the perches are wider on the older axles and therefore the u-bolt spacing ... does not work with the tacos lower shock mount plates. Simple as that.
