Basic Fram filters are about as bad as they come. Cheap construction and materials used.
Can't go wrong with factory Toyota or the other ones mentioned either. edit: Puralator's PureONE is a real nice premium filter. I like Amsoil. Mobil 1 and K&N are the same, except the K&N has the welded-on nut. WIX and Napa Gold are also the same. There's only several US factories that manufacture all of the different make oil filters.
Use the 3.7L Jeep Liberty filter (also found on some Fords too). It has the same OD and 3/4-16 thread as the stock filter, but is almost twice as long for increased capacity and efficiency.
Found this informative post. The OP found this on another site, but did not provide a link.
Oil Filters - Dissected
http://www.8thcivic.com/forums/mecha...dissected.html
I was wondering what the differences were between some of the current
oil filters. The study done at
Engine Oil Filter Study is quite dated. So, I bought some
oil filters from the local stores, grabbed my hacksaw and away I went. All filters had an anti-back flow gasket.
This image has been resized. Click this bar to view the full image.
Findings:
The basic Fram is still crap. Fewest pleats and therefore least amount of
filter area. Cardboard end-caps.
The TG Fram is better. Still has cardboard end-caps but has 15% more
filter media and a screened by-pass valve.
The XG Fram is, can't believe I'm saying this, a decent
filter. This is the
only filter tested that used a different type of
filter media. It was more fiberglass in nature vs. paperish for all the rest and is supported with a metal mesh. So even though it has less area, it is 2-3 times as thick.
STP and SuperTech are the exact same
filter. Decent
filter area but cheaply made and the felt end caps detached from the
filter media with frightening ease. No by-pass valve.
Mopar and Purolator PremiumPlus are the
exact same
filter. Plenty of
filter media with metal end caps which are impossible to remove from the
filter media as seen by the dead Mopar
filter.
Purolator PureOne and Bosch are the
exact same
filter. Largest amount of
filter media with metal end caps which are also impossible to remove from the
filter media.
All four of the latter are made by the same manufacture with the only difference between the two sets is the Mopar/Purolator PremiumPlus has the by-pass valve in the front, built into the stem..
...and the Bosch/Purolator PureOne has the by-pass valve located in the back via a 45-speed record adapter spring thingy along with 4 more pleats of
filter media. Also, the PureOne has the best paint job. A nice
royal blue w/ pearl coat
The Wix and NAPA Gold are the same
filter but the NAPA Gold had 4 more pleats (61 vs 57) than the Wix. Was this by design or was it a machine assembly variance, probably the latter since everything else was
exactly the same. The filters were similar to the Mopar and the Purolator PremiumPlus but made by someone else. They had a similar stem based by-base which was not attached to the
filter media but
loosely sits in the end-cap without a gasket. The Wix and NAPA Gold also had the second least amount of
filter media. They had metal end-caps with the
filter media permanently attached.
The Mobil 1 and the K&N are
exactly the same
filter less the 1" bung thingy on the K&N. Both are heavy due to their thick bases and smaller inlet holes. They too had the stem based by-pass valve firmly attached to the end-cap but only had 55 pleats, the second fewest. It did have the deepest pleats which equals fifth in area and the
filter media was slightly thicker than most. Had metal end-caps with the
Here the #'s (sorted by price):
