1 - 3 of 3 Posts
Anyone else who had neither
break light work?
Taillights work.
fuses are good.
There's no power at 4pin connector
at break peddle. should be 12v ?
Welcome to CT!
Here (attached) is the 2006 brake light wiring diagram.
Does your center brake light (on the cab) work? If so, it might be as simple as a bad ground connection for the other two lamps.
If you have VSC (stability / skid control) you've got a relay and the Skid Control ECU involved in the brake light circuit.
In any case, you should have 12v power at the Stop Light Switch, coming from the 10A Stop fuse if you don't have VSC.
1 - 3 of 3 Posts
