No Bracket 5 lug Budget Big Brake Kit
26297 Views 81 Replies 22 Participants Last post by  Fiebru2rz
For years people have made big brake kits for the 5 lug first gen tacomas but no one has ever offered much info or has used all custom parts that cost an arm and a leg. My goal with this was to find stuff that can easily be obtained at a decent price and share all the information i gathered openly. By pure chance i found these calipers that line up perfectly with the stock spindles. I have yet to finish the kit completely but ive mounted enough to share my findings so far. I still need to gather more information but this is about 95% complete. Hope this can help some people out. Also this will require a minimum 17" wheel. It will also depend on width and offset as well. My 17x9 +35 enkei rpf1s cleared with no issues.
Here are all the parts i used. I have yet to confirm that the brake lines will work for this application. So if buying these parts please wait until i confirm that they work properly.
Also please note that the amazon links below are linked to my partner account so i will net a small commision if purchased from that link. It doesnt cost you anything and i have listed all part numbers if you choose to search elsewhere for lower prices. But this is the lowest price i was able to find myself.
Disclaimer: the price of the calipers fluctuates regularly. The prices i have listed below are what i paid at the time i purchased them. You may have to wait for the price to drop to get the best deal.
As stated in the title the calipers mount directly to the stock mounting location on the stock 95-04 tacoma spindle. BUT the holes will need tobe drilled out to accept the larger bolt that the caliper uses and slightly shimmed out to align it with the rotor. I will list the drill bit size and shim size later when i have access to it again.
For the rotors (Evo 9 Front 12.6") those will need to be machined to fit the tacoma hub assembly. The center bore needs to be bored out and the mounting holes drilled and tapped to accept the stock hardware used to mount the hubs. I have attached a picture showing the modifications made.
According to the specs i found online the steel braided brake lines listed SHOULD work with the tacoma hard lines but like i said i have yet to confirm that so please wait on that. If anything the lines will be a little longer than needed but some creative routing solves that issue. Thanks to jose matos for confirming that.
Summary of parts
Cadillac ATS Brembo Calipers
Cadillac CTS-V Brake Pads
Mitsubishi Evolution 9 Front Rotors
Subaru WRX STI Front Brake lines
Brake Parts
Driver Side Brembo Caliper
PART #: 172-2586
COST: $104.14
http://amzn.to/2j08DwK
Passenger Side Brembo Caliper
PART# 172-2587
COST: $113.71
http://amzn.to/2j9BgCU
Caliper Hardware Kit
PART #: 18K1971X
COST: $18.58
http://amzn.to/2kn8Zy0
StopTech Steel Braided Brake Lines
PART#: 950.47006 $52.02
http://amzn.to/2jsw7qO
StopTech Street Performance Brake Pads
PART #: 309.10010
COST: $54.18
http://amzn.to/2jsyWYM
StopTech Blank Rotors (Evo 9 Front 12.6")
PART #: st121.46064
COST: $103.79
http://www.czeromedia.com/index.php/...optech-rotors/
Total: $446.42
Cost of rotor machining depends on what your machinist charges you.
  • Like
Reactions: 3
1 - 20 of 82 Posts
I forgot that you lose the ability to edit a post after a certain amount of time on here. Can a moderator add this information to my original post please?
Done ... :waytogo:
- Enola
Awesome! Do you have a picture of how they mount on the hub? Does it mount like the stock rotor or something?
With the modification it mounts the exact same way as stock. The hub bolts directly to the rotor.
Done ... :waytogo:
- Enola
Thanks Randy!
Also what are you planning to run for the mc? Think it'll hold up or is there a different one from a Supra or something to upgrade?
This needs to be a sticky once the lines are 100%
My brother had a similar setup and ran the stock master cylinder with no issues so thats the route im going. If i need to upgrade in the future I'll definitely post it up.
Final install willbe done this saturday so I'll post up an update then.
You should post up a video on youtube
I will be. I just didn't get any of the actual installation footage. My first son was just born last Friday so i didnt get a chance to record it. But I'll make a video explaining what went into the kit
  • Like
Reactions: 1
Hey no worries....Congats on the baby!
Thank you!
5
Finally finished the Brembo install!
The lines did work and everything feels fine. Here are some pictures of the completed install.
I attached a picture of the caliper mounted to the spindle with no bracket. The holes on the spindle need to be drilled out to accept the larger bolt and the caliper is shimmed out a few mm to line it up with the rotor.
I also attched some pictures of the completed assembly
  • Like
Reactions: 5
And a picture of the truck on the ground. Love the full look behind the wheels!
  • Like
Reactions: 1
1 - 20 of 82 Posts
