1 - 7 of 7 Posts
Hi my name is matt. I have a 2004 single cab 2.4 5spd. The truck has 338k miles. Former pest control truck. Runs like a top, fully maintained. Im interested in lowering it probably with the djm 3/4 drop, cut rear bump stops out and install mini bump stops. 17x9 & 17x10 silver sc style wheels that mustang guys run with 245/45 front and 275/40 rears. I have a few questions?
1. What shocks should i run? I know there are many choices but whats good and not too pricy?
2. Is a 26" tall tire ok with that drop?
Welcome to CT!
It must have been confusing to post for the first time when the forum was being totally overhauled.
About the tires ... How prepared are you to do some modifications like rolling fenders or shaving / removing front end skirting?
Even with a relatively modest 3/4 drop the wheel / tire sizes you quoted are a recipe for pesky rubbing.
The main problem with the tires you listed isn't the height - it's the width. Even with a mild drop, the front end clearance gets tricky once you get past an 8" or 8.5" width - especially in the front.
Using 10" widths in the rear is probably going to involve rolling the fenders. In an extreme case, a pre-Taco rear end needs to be used to get such wide wheels / tires to tuck at all.
Discussion Starter #4
Ok well im not looking to swap rear ends. I could roll the fenders, a buddy of mine has a fancy tool that bolts to the hubs for that. Ive seen a few trucks with similar setups but nothing extreme was mentioned.
You might get by without having to do anything as radical as a rear end swap with only a 3/4 drop.
It's hard to tell until you try it. Dropping gets to be a complicated 3D puzzle, and not everything can be reliably predicted based on theory and figures alone.
The wheel / tire spec's you listed are pretty radical, and staggered setups like that have proven to be problematical without a significant drop being done.
Naturally, it's hard to evaluate the possibilities without offset / backspace figures. I'm confident you'll probably have rubbing issues to overcome if you put 9" wide wheels on the front.
Do some searching on "staggered" / "stagger" (etc.) to see if you can track down previous postings about installing such a wheel / tire setup.
1 - 7 of 7 Posts
