Need help !!!!! I have a 97 boosted Tacoma but I changed my head and ecu to a 01 . My 97 chassi harness doesn’t fit on the last port of the 01 computer box . I have the 01 clip to depin so I can plug into my computer box . Anyone have a wiring diagram on what each color wire is each for ?
I do not have the ECU terminal pinout for the 97-year model specifically, but if my memory serves me correctly then it should be the same as the 96.
I have attached the data pulled from both of the respective manuals that I have for the 2/3RZ engine, which I assume you have. But it's just an assumption based off how common it is to boost.
If these do not help you then maybe @Enola Gaia can chime in with some more data. I'll keep digging around to see what else I can find.
