1 - 15 of 15 Posts
Just a little background. I have a 98 extended cab with a 2.7. This is the 3rd time I have owned this same truck. It's been passed around to some close friends as works truck throughout the years. I am now in the process of making a budget friendly lowrider. Me and my boys are taking our time and enjoying the toy. I will post some pics of the progress along the way.
Wheel Car Tire Vehicle Automotive tire
Tire Wheel Car Vehicle Land vehicle
Car Automotive parking light Vehicle Land vehicle Tire
Discussion Starter · #2 ·
So the first things I did was cut my coil spring. Did the b/j flip and ran a mono leaf on the rear. Had no suspension travel so went ahead and put in a big c notch because I knew I was bagging it in the future.
Wood Motor vehicle Automotive tire Automotive exterior Gas
Automotive tire Wood Door Gas House
Tire Wheel Vehicle Automotive tire Motor vehicle
Discussion Starter · #3 ·
The next step was to get the bed back on and now I had notches in the way. I decided to do a shallow bed floor. Cut out the old bed floor and saved it for a few months till after I four link and bagged it.
Automotive tire Wood Motor vehicle Gas Automotive wheel system
Tire Car Wheel Hood Automotive tire
Automotive tire Wood Motor vehicle Bumper Automotive exterior
Discussion Starter · #4 ·
The hood had came up once and hit the roof. So I cut the skin off a new c class Mercedes and glue and river it on to cover up the old damage. Couple pics of progress I will add photos of it finished in Primer in day or two.
Wheel Tire Bicycle Table Road surface
Vehicle registration plate Vehicle Car Grille Automotive lighting
Discussion Starter · #7 ·
So after riding a while it was time for a fourlink. Tried to do a fair amount of research on axle geometry. So keeping budget in mind bout a cheaper kit and installed the four link.
Motor vehicle Automotive tire Automotive exterior Gas Auto part
Automotive tire Motor vehicle Wood Gas Automotive exterior
Automotive tire Motor vehicle Wood Bumper Automotive exterior
Discussion Starter · #10 ·
So it is alot further along than some of my pics. Life slows progress quite a bit though. I wanted to do a shallow floor in my bed. I cut the floor out and built a shelf out of rear and reinstalled the floor. I used a 55 gallon drum as tubs to clear the tires.
Property Hood Automotive tire Bumper Window
Wood Automotive tire Floor Composite material Automotive exterior
Grille Automotive tire Bumper Automotive lighting Rectangle
Wheel Tire Car Vehicle Land vehicle
Land vehicle Vehicle Car Grille Motor vehicle
Discussion Starter · #11 ·
So none of the body work has been getting done yet. The previous owner had the hood fly up and hit the roof. I decided to make my own. I grafted a skin off a Mercedes hood.
Car Land vehicle Vehicle Sky Automotive lighting
Car Vehicle Motor vehicle Grille Automotive tire
Discussion Starter · #14 ·
That has all been done for a while now. I am currently working on bagging the front. Have not done this before so taking my time. I am doing the right side first to make sure it works out. Then I will.use it as a pattern for.the left.
Motor vehicle Automotive tire Bumper Vehicle Automotive exterior
Wheel Tire Motor vehicle Automotive tire Tread
Car Automotive parking light Land vehicle Wheel Tire
Discussion Starter · #15 ·
I still have to relocate my shock. Weld in a few support brackets. Also have to make a bracket to raise my upper control arms. I have read plenty of times about guys moving upper control arm. I never understood until I saw the suspension geometry myself. Then it was eye opening.
Tire Automotive parking light Wheel Land vehicle Car
Tire Wheel Automotive lighting Automotive tire Vehicle
Tire Motor vehicle Automotive tire Tread Vehicle
1 - 15 of 15 Posts
