61 - 65 of 65 Posts
Oh, crap ... Sorry to learn it was blocked ports. Maybe not catastrophic, but irritating because it requires additional work and hassle.
hey do you think that the piston rings or other stuff are compromised? I wonder if the temp the scanner was reading was correct for those cylinders since they didn't have coolant flow... I'll just get the heads worked and put in new toyota bolts as and gaskets. they havnt responded yet
Unless you can find evidence of ring damage (whatever ... ) on visual inspection I doubt you'll be able to tell much until you reassemble everything and do a compression check.
61 - 65 of 65 Posts
