1 - 3 of 3 Posts
This winding sound I have.is loudest in 1st gear.then gets quieter as I move up the gears.if clutch is pressed.it goes away.it sounds like that noise when your in reverse.backing up.any one familiar with this?any possible solutions.or idea's. Appreciated.
Does the sound occur with both the 4WD engaged and disengaged?
Have you checked your transmission and clutch reservoir fluid levels?
Can you describe the sound you're hearing any better? I'm not sure what you mean by a 'winding' sound. Do you mean a high-pitched whining like something mechanical revving / winding higher?
Does the sound change pitch with rpm's? (Does it get higher in pitch as you move faster?)
1 - 3 of 3 Posts
