its a 2002 prerunner with the v6,since no rear drop kits were found i had to resort to a drop kit that had no mount for the rear shocks,took it to a shop that fabricated new mounts for the shocks and installed them.The drop kit flip kit did about 5 inches of drop,the lean i was talking about is the front being a lighter higher than the rear and i am looking for a way to get the front leveled with the rearClues, please ...
What are the specifics on your PreRunner? (Year, etc.)
Exactly what "flip kit" is it you've had installed, which shocks were relocated, and how were they relocated?
What is it about your Taco's stance this "flip kit" did? Raise? Lower? How much?
This "lean" ... Are you talking about the usual "Taco lean" (driver versus passenger side)? Since you're asking about dropping the front, I'm not sure whether you're concerned about side-to-side or front / rear "lean."
Nope, sorry ... I have no way of comparing the bolt spacings between the 2 generations' struts. If I had to guess, I'd guess they're not the same.... May be able to swap to 05 and newer struts but unsure if the bolt spacing is same. That's a @Enola Gaia question for sure
