Those are easy. Once you unbolt the caliper it should slide right off... If it doesn't get a hammer and hit it off. Then just slide the new rotor on, bolt up the caliper and you're good to go. The 6lug tacos are easy cause they use a floating rotor.
that must be niceThe 6lug tacos are easy cause they use a floating rotor.
