1 - 6 of 6 Posts
I am getting vibration at 40mph. I took my truck in to have the tires balanced and was told it's most likely my carrier bearing. Has anyone had experience with this issue?
A bad carrier bearing or a driveshaft misalignment on either side of the carrier bearing could result in vibration issues.
Does the vibration seem to come from underneath and about halfway back (to the rear)?
Have you done any mods that resulted in raising or lowering the truck?
I'm not sure where the vibration is coming from. It seems to vibrate the entire truck. I have a 4" lift and 33" tires
If there wasn't any adjustment to your driveline alignment done with the 4" lift, it might well be the carrier bearing.
Discussion Starter #6
But it was fine for a while after the lift was installed and it seems to be getting worse
1 - 6 of 6 Posts
