Lift?
816 Views 1 Reply 2 Participants Last post by  nofords08
Are there any other advantages to a suspension lift if you do not plan on installing bigger tires?
Do you end up with more suspension travel?
As i understand the only way to get more ground clearance is with bigger tires.
1 - 2 of 2 Posts
depends on the lift. a drop bracket keeps stock amount of wheel travel, a spacer lift takes away wheel travel(i believe someone else will chime in if i'm wrong) and long travel obviously adds wheel travel. why don't you want larger tires? thats the only way to get your diff off the ground
also coilovers such as toytec and sway away and icon will give you lift and a better ride
1 - 2 of 2 Posts
