LED Flasher Relay
8840 Views 7 Replies 4 Participants Last post by  evanch
I am looking for an LED flasher relay. I installed LED bulbs and need a flasher relay to slow down the hyperblink. I have a 1998 tacoma. Any links to where I can buy one that works for sure would be great.
1 - 8 of 8 Posts
Many of the LED vendors carry LED-compatible flashers. For example - check out autolumination.com:
http://autolumination.com/equalizers.htm
which one fits tacoma?
the fastest and most reliable option I have used is the V-LEDS blinker relay. It has a couple splices that you splice on the wires and you are done. :clapping:
I thought it was awesome
http://www.v-leds.com/BlinkerWarning-Fix/Turn-Signal-Fix/6-OHM-50W-2-BULB-LED-p4783296.html
Or, you could get the flasher relay, unplug one and plug the other in and you're done.. :D
Which one do I need? I haven't taken the old one out and have no idea how many pins it has or what it looks like??!!
The most straightforward thing is to remove the OEM flasher and see ... :thinking:
Here (attached) is a diagram illustrating its location in Junction Block No. 1 (the relay / fuse box behind your lower left dash).
Take it apart, put it back together, order part, take it apart, put it back together. I'm not lazy just dont like doing stuff twice. Anyone have a pic or number off an OEM relay for a 1998 tacoma. I saw one for a 2001 could it be the same relay?
1 - 8 of 8 Posts
