21 - 23 of 23 Posts
Discussion Starter · #21 ·
What size ARE those tires on the stock rims of the 2002?
If you mean Jesse's 04 in this thread, 205/60-15 at 24.7" in height. No rubbing at all in front!
how much of a notch is required for this? and does it bottom out the shocks?
Just a normal size notch, less than 1/2 of the frame removed, and no it won't bottom out stock length shocks.
Thanks so much, I was searching like crazy for some more detail on welding a washer to the wall.
On another note, I know I shouldn't reuse ubolts, but will I be able to reuse them even for a short while with 1 leaf pulled from the 6 lug leafs? I just want to have them on there long enough to see the springs settle so I can see how big of a spacer/new unbolt to order.
Yep, it'll be fine.
Discussion Starter · #22 ·
21 - 23 of 23 Posts
