I replaced both leaf springs with 90-201 and 203 toyo rear spring set this year and the back end is sagging and on the axle if I load more than 400lbs. Any recommendations how to fix with out replacing the new springs again as this was a bitch and expensive. Thanks
these are what i run
http://compare.ebay.com/like/300561665373?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar&_lwgsi=y
although i dont like their design. goodyear makes a really nice set that support on both sides of the axle rather than just one. they take up to 100psi. ive put mulch as high as i could pile it put 90psi in those bad boys and got a good inch of travel. they raelly really work well. you can adjust your truck to ride high (or even high) with any load you put in it.
but as far as whats wrong with yours..... i have no idea. how do you know the truck is sagging? got any pix of leafs / suspension?
have you overloaded the truck (aka loading it with mulch as high as you could pile it? do you leave a lot of weight in it (water tank)
well if the answer was yes you probably wouldn't have written this thread.
so back to the fact that i have no idea. :looney:
