are they comparable to the jl unti? and do you have experience with any of them? if so what is your impression on them.BRB GTG PP said:Rockford and AudioControl have them too.
vtechthis said:anyone have any experience with one of these units? the model number is cl441dsp. it is supposed to be amazing for connecting high quality sound systems to a oem head unit. which is what im plannign on doing.
hmm see i was told by a reliable source that the clean sweep paired with soem nice amps and a nice eq will sound pretty dang good. that is why i wanted to see if anyone has used one with the 05 taco head unti to see if it in fact sounds good with our head units. oh and i wouldliek to keep the stock head unit not to be cheap because money nto a huge deal but i would liek it to be some what sleeper.GSX-Runner said:Don't do it! Put your money toward a new head unit. You will get sick of the stock h/u's limitations. Remember, your system is only as good as its weekest link..
:waytogo: even though he drives a honda i have to say that man is right.:lol:Ta-low-ma said:I believe what he's going for is that semi-stealth stereo to keep the thieves away but also have a very good sounding system. I do know the Clean Sweep has a built in EQ but instead of having Bass and Treble controls it actually Flattens the normally peaky sound of an OE headunit.
what is the price on the rockford?Gumby said:Is it similar to the Rockford Fosgate 3sixty.1 and .2? if it is I will tell you all about it next week. But my rep at rockford tells me you can run it off a stock headunit and have aftermarket quality still
what kind of converter were you using?George4drV6 said:I dumped my head unit after a week of installing my MB Quarts and amp before swapping it out. My new head unit sounds incrediblky better. I wanted to the stealth install but needed sound and the stock HU couldnt cut it.
vtechthis said:what is the price on the rockford?
The Scosche one. You just cant get any quality that way. If you want to add a sub to the stock system then it is great, if you want the chagne the sound stage then upgrade the big 3 starting at the source.vtechthis said:what kind of converter were you using?
