"98 extended cab 2wd 5spd"
off of what vehicle do i need to get a ford 9" axle from? will the axle bolt onto my leaf springs? once bolted, I then have to get some fab work to get the drive shaft bolted?
measure between the center holes onyour axle and axle width and go searchin at a junkyard.. its gona be hard to find an axle that sits atop of the leafs like our axles do, however you can do a flip kit with weld on perches.. and that isnt too hard at all:waytogo:
Explorer's do not have 9" rear ends...
Dude... go to any junk yard, find the old rear wheel drive fords.... mid 70's will work fine.... you will fine HUNDREDS of old 9" rear ends..... we used them in every racecar we ever built.
Exploders have 8.8" rears with disc brakes. You can also get the 8.8" from a 2000-up Ranger if you can't find an Exploder one. Disc brake conversion kit is $350 or so. I have an 8.8' from a 2000 Ranger with 3.55 ring and pinion and a LSD that I'll let go for $100 if you wanna pick it up from Jax, FL or pay for shipping on. Getting rid of my Ranger project. Making room for an X.
i'll suggest the 8.8 rear too.
you will see significant parasitic power loss with the 9 inch... my V8 Pinto came with a 9 inch, and when i put an 8.8 in out of a 89 5.0 Mustang in it, i actually increased wheel HP. ( engine over 600 )
one thing for certain, you wont break the 9 inch no matter what power levels you are running... but with a 2.4L, you wont break the 8.8 either.
dave
I completely agree.
The 8.8 is a bad ass rear end.
The 9" is MUCH stronger....
but with the amt of power you are talking about, I dont think you have anything to worry about with the 8.8
If you have a torch, a grinder, a good welder, and a measuring tape, there isnt much that you cant do. only issue might be driveshaft extension / shortening, in which case you'll want a machinst's touch to maintain balance.
1 - 10 of 10 Posts
