A case of beer, cuz if you've never had ur trans out, its a b*tch ur first timeother than the w58 of course, what other parts would i need to buy?
X2. it was definitely a fun time getting that bastard out. especially in 110*.A case of beer, cuz if you've never had ur trans out, its a b*tch ur first time![]()
Gear lube.
I would change your shifter sub assembly bushing while your in there, and possibly your tail shaft seal.
All of the above, beverage of choice.A case of beer, cuz if you've never had ur trans out, its a b*tch ur first time![]()
tighter grouped gear ratios and strength. writeup is for 2rz or 3rz. but possibly applicable to other w-series equipped vehicles, pending they have correct sensors. my w58 came with an extra sensor on top that i didnt use.What's the advantage of the w58? also, what engine was used in the write up. and what engines does this apply to?
Thanks for your contribution Chris! Also, the truck in your sig looks amazing. Probably the best looking lowered Taco I've seen.
Am I missing something, these seem contradictory? They're both grouped tighter, and 1st and 2nd are longer?With the Supra W58, 1st and 2nd gears are much longer than the Tacoma's and the gearing is more sports car like vs stock..
It has a nice flow between gears and you'll drop some RPM's in 5th on the freeway..
You are not missing anything. This is a very over exaggerated example, but will help you understand the concept.Am I missing something, these seem contradictory? They're both grouped tighter, and 1st and 2nd are longer?
What is your current rear gear ratio?Sweet! Any questions, hit us up!
I bought a used 3rd member from BlazinS10..What is your current rear gear ratio?
I wanted to know about a few things and since your gearing is about the same as mine I should be able to compare. At what rpm do you start boosting? If I remember correctly you also have a 2mm head gasket. With the longer gears from the w58 do you regret going with the thicker head gasket resulting in loss of N/A power or do you boost early enough to whwere you don't notice it? I personally don't like the loss in N/A power outside of boost but with 91 octane fuel you can only run so much boost without dropping compression.I bought a used 3rd member from BlazinS10..
Not sure if its the same gearing as stock (5spd) or if it was from an auto.
Not much of a difference, but with 215-50-17's, my speed is about 1mph off @ 60 according to my gps.
