How to install Foglights
1105 Views 3 Replies 4 Participants Last post by  Tred
How would i go about installing fog lights so that they are independant of the headlights...so i can turn them on without turning on the headlights
You can hook it up on an independent 12v source (ie cig lighter, ign circuit, or off of a different source) then hardwire it's own switch in.
thats your best bet so that theres no chance they would be on when the trucks off to drain the battery. most fog light kits you get come with the wiring kit and switch
To clarify, you need a relay and a switch to control the relay. Additionally, beyond what you're trying to do, you have the option to have the switch connected to an ignition controlled source or one that is always powered. Look in the wiring diagram if your fog light kit came with one.
