So I’m getting a knock sensor code, I found the wire to the knock sensor and it’s melted off the actual sensor. I bought a new sensor but I’m not sure how to change it out? 1999 1.4 Toyota Tacoma
The knock sensor is just threaded into the block. The connector connects right to the sensor. If the connector is melted you might have more problems than you think. Can you post a pic of the connector that has the wire on it?So I’m getting a knock sensor code, I found the wire to the knock sensor and it’s melted off the actual sensor. I bought a new sensor but I’m not sure how to change it out? 1999 1.4 Toyota Tacoma
