The heads are usually the same, depending on year. Same "architecture"oh thanks man, just a few more questions.
Do the 2.4 and 2.7 share the same head?
is it worth swapping out the 2.4 for a 2.7 for quicker spooling and better power band?
There were 4 port and 8 port heads, the change happened around 99-00. 8 port heads are alittle better for boosting. Both will be good so having a 4 port is not a deal breaker. Some heads are set up for distributor, coil packs, etc.
The 2.7 is better if you plan on low boost. But the 2rz bottom end is good to 18psi safely stock, where a 3rz bottom end is only good to about 14-15psi safely. You will make more power, safer, on a 2rz. The 3rz is only better if you are upgraded to forged rods/pistons.
What metal hg are you guys running?My motor is stock but hg and studs. 15psi on meth all day long.
I was pushing 21 psi with stock hg and studs.
Tune is very important.
How many miles are on your truck now C?Same head. Just different blocks. 3rz has a longer stroke to make up the difference. I am 18psi stock engine, putting down 300/332 currently. It's my DD too. Have about 15k with the current setup. No problems yet. *knocks on wood..
What fuel pump are you running while pushing 13psi? Fuel pressure regulator?13 PSI stock engine. Turboed for 6 years now. Daily driven.
I see luis on facebook a lot, search for 2rz/3rz turbo community.
URD Walbro 190 lph fuel pump. Had stock regulator which worked good but changed it to Turbosmart FPR800 regulator with gauge. 440cc injectors. URD maf calibrator to control fuel.What fuel pump are you running while pushing 13psi? Fuel pressure regulator?
Do you know if elevation would have any effects? Out here in coloradoURD Walbro 190 lph fuel pump. Had stock regulator which worked good but changed it to Turbosmart FPR800 regulator with gauge. 440cc injectors. URD maf calibrator to control fuel.
13 PSI stock engine. Turboed for 6 years now. Daily driven. I see luis on facebook a lot, search for 2rz/3rz turbo community.
Hey, are you running a stock 3rz-fe? I’m about to boost mine and I’m doin some research13 PSI stock engine. Turboed for 6 years now. Daily driven. I see luis on facebook a lot, search for 2rz/3rz turbo community.
