What about the A44D auto transmission? How much can it handle?If it's the manual trans, then somewhere below 400 crank torque. I daily'd 5psi on the stock W59 5-speed and bone stock rear end until I upgraded to the W58, which is the same case basically but different ratios. I am now at 22lbs of boost, beating the **** out of the truck and racing it in autocross, and the W58 and stock 7.5 rear end with 4.11 gears and Detroit Tru-Trac LSD handle it no problem. My engine is built now, did that back in 2018, but the stock engine has been known to hold 15+ psi no problem as long as you have a good computer to get a good tune. These engines are incredibly resilient if tuned properly. Your's being an 03 you have a better head gasket than the pre-01 trucks, so you shouldn't need to worry about the head gasket until you start tipping over 10lbs of boost or so. If you're willing, you can do head gasket and head studs and be good to support somewhere near 20psi (as long as you can tune it). I've had a boosted 2rz since April 2012, so tons of experience, let me know if you have any questions or concerns.
No clue, not many people with autos do the turbo stuff. There's a been a few, but not many.What about the A44D auto transmission? How much can it handle?
What do people usually do for tuning on turbo setups? My truck is a 96 so it's a distributer motor. I've read some about the pink top injectors, I'm seriously considering a turbo setup on my buggy, that or a 1UZ swap. It could really use some extra power to turn the 43" tires. I tried to PM you but I just made the account so it won't let me. I know about wrenching and fab but the only vehicles I've messed with tuning on are diesels. Thanks.If it's the manual trans, then somewhere below 400 crank torque. I daily'd 5psi on the stock W59 5-speed and bone stock rear end until I upgraded to the W58, which is the same case basically but different ratios. I am now at 22lbs of boost, beating the **** out of the truck and racing it in autocross, and the W58 and stock 7.5 rear end with 4.11 gears and Detroit Tru-Trac LSD handle it no problem. My engine is built now, did that back in 2018, but the stock engine has been known to hold 15+ psi no problem as long as you have a good computer to get a good tune. These engines are incredibly resilient if tuned properly. Your's being an 03 you have a better head gasket than the pre-01 trucks, so you shouldn't need to worry about the head gasket until you start tipping over 10lbs of boost or so. If you're willing, you can do head gasket and head studs and be good to support somewhere near 20psi (as long as you can tune it). I've had a boosted 2rz since April 2012, so tons of experience, let me know if you have any questions or concerns.
