No your oem cap is rated for how much psi is in that radiator so adding a new cap that can hold more wont change anything....
No your oem cap is rated for how much psi is in that radiator so adding a new cap that can hold more wont change anything....Is there any risk by using a higher pressure than stock radiator cap?
The 5VZ comes with a 13 psi cap and I'm using a TRD 19.5 psi.
Any thoughts?
Thanks in advance.
I'm talking about the stress that the extra 6.5 psi adds to the cooling system, will that damage any component? Radiator, hoses, water pump? :shrug:No your oem cap is rated for how much psi is in that radiator so adding a new cap that can hold more wont change anything....
ThanksNO it is fine, I run high pressure caps in everything to raise the boiling point of the cooling system.
Did the earthquake affect you Pug?? Hope your OK.
