I know some of you have had this issue before - I have an 04 tacoma and my heater control valve won't open all of the way. When i turn the switch from hot to cold in the truck the valve will turn almost all of the way but it gets to a certain point and then toggles ("thinks") back and forth and will never open completely. I took the cable off the valve and manually have it opened all the way at this point but I am not sure what I need to do to fix this and/or how in depth it will be.
Do I need to replace the valve or is it something else in the system that needs to be checked? I searched but only came up with people having issues on 99-00 models which evidently have a little different set up.
Any help would be appreciated!
