The wet sand papers I've seen were Wet/Dry sand papers, and they work just fine without water, but it slides better with water as the sanded material doesn't gunk up. You've probably noticed this.SRakaSSS said:Not to thread jack, but when using the wet sand paper, must the lense and the paper be wet for it to be effective?
thats exactly what i did mine to get my headlights lookin brand new again. that rubbing compound is the sh.it:waytogo:mobile 1 said:Get some 3M rubbing compound (perfectII) and clean them with that, then get some 3M hand glaze to follow. It might take a couple times, and if that doesnt work then use 2000 grit sandpaper like that other member said, and keep the paper wet and dont go in circles! Then follow up with the two steps mentioned above. Then everytime you wax your truck, wax the lights too for protection and you'll be cool!
