Wheel Tire Plant Car Land vehicle
I started to drive my tacoma recently it ran and drove fine until one morning it had a fuel cut / misfire I have replaced intake gaskets incase of vacume leak along with spark plugs, plug wires, distributor, injectors, fuel rail, and fuel pump now I am out of ideas on what would cause it. Looking for help and hello from Idaho
Is the check engine light on? Have you checked for any stored codes?
Agreed ... First thing to do is check for codes and post them here so we can see what the ECM 'thinks' is wrong.
Fuel cut/misfire? Are you chasing an issue that's persisting or a random fluke or hiccup that occurred?
Check to see if the pcm did a snapshot with a pending code. Will tell you if something to chase or just a gremlin
