So does that mean you are giving up on me!? what else can I do? should I just suck it up and take it to toyota? I just don't want to have to pay if I don't need to.
thanks for all your help randy. It's greatly appreciated.
It's not that I'm giving up on you ... It's that these latest symptoms pretty clearly mean there's a general wiring fault (short, bad connection, whatever ...) somewhere in the peculiarly rewired circuitry of your particular truck.
The only solid clues in what you've reported so far are:
(1) All the affected circuits use ground points IE and / or IG.
(2) The symptoms go away when the DLC3 connector is hooked up (and opens a ground link to IE and / or IG).
It seems clear the solution has to do with grounding. That doesn't necessarily mean the root problem is a matter of grounding alone. It could be any of a number of things such as:
- a fried or shorted component (possibly including the main fuse block and the ECM)
- bad connections / connectors
- mis-wired harnesses (the aftermarket wiring you've installed)
- a short or broken connection anywhere in any of the wiring associated with the affected circuits
Since there are aftermarket harnesses / wires / components involved, I can't decipher the symptoms' logic on the basis of OEM wiring. I can't even tell which wiring / circuits may be the problem (OEM versus aftermarket).
In my opinion, you're never going to get this sorted out until and unless you:
- start dismantling the electrical stuff you've installed, one piece at a time, until you find everything works as it should again (which probably, but not necessarily, indicates the last thing removed is the main problem).
And / Or ...
- start painstakingly testing the current flows on each and every one of the affected circuits (which means pretty much everything around your engine bay and dash area).
It could still be one single frayed wire, bent pin in a connector, bad ground, etc., etc. The point is that the faults affect so many different circuits (and so much wiring that's not even reflected in the OEM wiring diagrams) that I can't reasonably expect to diagnose it from a distance.
It's not a matter of electrical 'logic' for any similarly-configured Taco. It's a matter of electrical gremlin(s) in your specific Taco.
